LT1 TB question
Old Apr 6, 2006 | 11:22 PM
67ProStreet502's Avatar
LT1 TB question
I just bought a 93Z, and had to buy a TB for it (Thanks 383TransAm). Unlike my TPI TB, which has no hole below the Throttle blades, the LT1 TB has a hole. It's like a bypass to the IAC it seems. I was wondering why. The 95 and 93 tb both have this, so I'm guessing all LT1 TBs are like this, but why?
Thanks,
D.J.
Old Apr 6, 2006 | 11:33 PM
ibanez6rg's Avatar
Re: LT1 TB question
So they don't die when the blades are closed.
Old Apr 6, 2006 | 11:53 PM
Dan Parker '96's Avatar
Re: LT1 TB question
You can consider the bypass as a "baseline" idle airflow. It is sized so the IAC (Idle Air Control) stepper solenoid can help stabilize the idle (through little idle air passages drilled in the intake manifold).
This "bypass" hole is normally enlarged when a larger cam is installed and manifold pressure instability ensues. It allows the IAC to help "fine tune" (a relative term depending on the severity of the cam) the idle characteristics.
oldschool
Feb 9, 2016 09:21 PM
cmdeshon
Dec 27, 2014 10:06 AM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
Camaro90RS
Jul 23, 2002 07:57 AM
