Lt1 swap issues
Old Aug 25, 2019 | 05:19 PM
Mccormicks's Avatar
Lt1 swap issues
I need more brains on an issue im running into. I have swapped a 95 lt1 into a 84 camaro. Im running stock ecm. I have no fire on my fuel pump wire. I have a timer bypass module for the vats system. I believe that is my issue but i cant be certain. I had 12v on the fuel pump relay wire the first time i powered up. Now i cannot get anything. I have "reset" the ecm and nothing. I do not have power to my injectors either. 12v has been present on the pink and orange wires everywhere i have checked except the injectors. She will run all day on manual added fuel. I have jumped fire to the fuel pump and still nothing. What am i missing? What is the truth on vats shutting down the fuel pump ? Should i stop until i wire up a diag port and read codes ?I know the 12v to injectors is a huge issue i will dig into tommorrow. However it doesnt explain why i had that 12v signal on the fuel pump relay wire and then disappeared. There wasnt power at the injectors then neither so i dont believe its a power issue to the ecm. Im assuming i have a bad feed to injector harness. Does the ecm or donor care supply the key on 12v to the injectors ?
Old Aug 25, 2019 | 05:35 PM
chevykid's Avatar
Re: Lt1 swap issues
i would say its the VATS, i don't know if the security light comes from the computer, if it does, you might want to hook one up so to know for sure.
The VATS cuts off the fuel pump, injectors and starter on a normal '95 lt1.
Old Aug 25, 2019 | 05:48 PM
Mccormicks's Avatar
Re: Lt1 swap issues
Have you heard of any issues with the cheap timer.shop bypass modules ?
Old Aug 25, 2019 | 06:40 PM
chevykid's Avatar
Re: Lt1 swap issues
one i was looking at years ago was $100, this one looks like it does 30hz & 50hz i know 95 lt1 uses 30hz so you might check and make sure its putting out 30hz, because if the computer doesn't get 30hz it will lock out. they say the blue wire has to be grounded so maybe it came loose or not working at all.
Old Aug 25, 2019 | 07:43 PM
Re: Lt1 swap issues
If you don’t have ignition switched 12 volt power to the pink wire (stock LT1 wiring harness) at each injector, it is not the result of VATS system. There is nothing between the battery and the injectors except the wire, a fuse (actually 2 fuses, 1 for #2/3/5/8 and 1 for #1/4/6/7), and the ignition switch. Key on should show 12 volts on each pink wire. You won’t have a ground present on the other wire, because the PCM supplies a ground to each cylinder in the firing order sequence to fire it. You need a ‘noid light to detect that ground pulse.
There are codes that prevent the PCM from restarting the fuel pump (after the 2 second prime/shutoff), and/or firing the injectors. Have you scanned for codes? One of them is DTC 46 for no fuel enable signal from the theft deterrent module (or bypass module in your case) to the PCM. Absence of the cam position sensor pulse signals from the optical module in the Opti will also shut down the fuel, and set DTC 16.
In any case, the fuel pump should always prime for 2 seconds, then shut down when the key is turned to run, whether the VATS system is working or not. The engine may even start and run for a few seconds on the residual fuel in the rails.
Old Aug 26, 2019 | 10:41 AM
bw_hunter's Avatar
Re: Lt1 swap issues
It might be obvious after Injuneer's post but I'll mention it anyway. Test the voltage at the injectors using an engine ground, not the other wire on each injector...
Old Aug 26, 2019 | 11:22 AM
Mccormicks's Avatar
Re: Lt1 swap issues
Okay the injector issue was my own wiring mishap. I didnt have any hot hooked to my harness on either side.Now my fuel is good. New issue she will fire up 2 seconds and die. Still dont know why my ecm wouldnt give power to my fuel pump relay. But now it is. Sensors un hooked are maf, iat, temp, o2. Next step i suppose is hooking up a diag. Will i have codes from the evap and egr being removed ?
Old Aug 26, 2019 | 11:26 AM
Mccormicks's Avatar
Re: Lt1 swap issues
Are we should 95 is 30mhz ? This whole time i was under the impression it was 50 in 95
Old Aug 26, 2019 | 02:33 PM
Re: Lt1 swap issues
Did you check for DTC 46? That will tell you if the PCM is receiving the correct fuel enable signal from the bypass module.
Not sure, but I thought 1993 was the last year that used 30Hz.
Old Aug 26, 2019 | 04:26 PM
chevykid's Avatar
Re: Lt1 swap issues
if you google it, you get answers for 30hz & 50hz for '95 so what i would do since your module does both is try one, then try the other, its not going to hurt anything, one will just not work. if i had a frequency meter i would check mine.
Old Aug 26, 2019 | 09:11 PM
Mccormicks's Avatar
Re: Lt1 swap issues
I have rebuilt another harness to double check each wire. Everything is perfect. Honestly i cannot find a single issue anyehere now. Car still only runs 2-3 seconds. Im not losing fire and injectors are not stopping fuel pressure is stable. I can run all day on spray but only 2-3 seconds on injectors. I ran the motor before the swap and no issues were present. One other thing i noted was it seems to be loading up. She will sputter and bog but i can pull my fuel relay and boom 3 second run time. Im running an external jaguar pump anf thought maybe to much pressure but the regulator should fix that i would assume.
Old Aug 26, 2019 | 11:50 PM
chevykid's Avatar
Re: Lt1 swap issues
I'm not sure on this but i think if the computer thinks one of the injectors is shorted it will shut them all down. i remember a guy's car died on him because of that issue so he just unplugged that injector and ran it on 7 cylinders till he got home. so you could try unplugged each one to if that is the issue. but again if had more than one that wouldn't work.
Old Aug 27, 2019 | 11:16 AM
Re: Lt1 swap issues
Only the driver for the injector that showed a fault will be disabled, not all of them. Direct quote from the 1995 factory service manual, page 6E3-A-50, covering DTC 18 - Injector Circuit(s):
DTC 18 Will Set When: The PCM detects the wrong voltage potential on any of the injector driver circuits for 4 seconds or more.
Action Taken (PCM will default to): The PCM will disable the injector driver on the particular injector that had the fault. DTC 18 will be stored in the PCM memory but will not turn "ON" the Malfunction Indicator Light (MIL).
Diagnostic Aids: If an injector is disconnected and then reconnected while the engine is operating, the injector driver will be disabled for a predeteermined time and DTC 18 will set. When the driver is disabled, an engine miss will be apparent.
Old Aug 27, 2019 | 12:47 PM
chevykid's Avatar
Re: Lt1 swap issues
i'm glad that is so i would hate to have my die somewhere because of one injector.
I'm glad we have you 'injuneer' to give us the right answer, ( you know that saying 'if its on the internet its true' )
Old Aug 27, 2019 | 04:59 PM
Re: Lt1 swap issues
Well, I have found errors and contradictions in the factory service manual, particularly when things change from one year to the next, but they don't catch the changes required in the next year's manual. I am always open to seeing a citation form a different source if there is a conflict.
