Lt1 stumbles and hesitant
Car was driving fine all of the sudden it starts to hesitate and stumble. been like that since. o2,coil,ICM,opti,plugs,plug wires,wp are brand new.It runs cool with a 160 stat and with the ECM being reprogrammed for cooling features. wtf
the car just started doing that out the blue.plug wires are fine and fuel pressure is great ! wtf! It does not do it upon idle, it does it when its driven.
FYI -opti,ICM,plugs,plug wires,coil,o2's,wp are all brand new
any suggestions?
any suggestions?
That sounds like what mine was doing a couple of months ago, It drove me crazy and would drive fine, idle fine and whenever you put it under a load it would act like a backfireing q-jet. After checking all the sensors, and the obvious it was the coolant temp. switch, its on the water pump, you can test it with a ohm meter to see if its in specs,well I know you can on a 94 maybe some other guys can corect me, can you test the sensors on the 95 and ups? Not sure if thats whats wrong with yours but thats how mine was runing, good luck.
Coil wire from coil to distributor is good, I changed it wit another wire and same results. I changed All sprk plugs and same results. I checked ALL spark plug wires for any burned wires there were none and I replaced the TPS she is still hesitant and now she is stumbling/hesitant on idle as well
Fuel filter. Mine was doing the same thing and that took care of it. Might try it, it's cheap and good maintenance anyway.
Btw, was the opti a delco unit or a reman or what? opti could be the issue also, i've heard of bad reman units out of the box.
If it's dropping to zero after priming, then you may have a fuel injector leak or maybe a problem with the check valve in the gas tank.
Pull the fuel rail and injectors. Prime it....see if an injector is leaking.
