lt1 stock crank and rod limits ?
Old May 5, 2011 | 10:06 PM
twistedbowtie's Avatar
Arrow lt1 stock crank and rod limits ?
im looking to rebuild a lt1 for now im just doing the bottom end. im planing too have the block cleaned and bored 30 over (or least as i can cleaning walls) cranks turned (possibly) rods line bored. my question is what will the stock crank and rods hold? i know allot of people say the old 350 bottom ends will hold 500 hp at flywheel. will the lt1 do the same?
im looking to build a stout motor not sure the specs i want yett but heads/cam maybe small shot of nitrous or s/c undecided
any input will be helpful, thanks
Old May 5, 2011 | 10:38 PM
henryz28's Avatar
Re: lt1 stock crank and rod limits ?
Yes 500 flywheel hp will be fine I would install arp rod bolts. The stock crank can hold well over 500 flywheel hp. You can get 500 flywheel without the nitrous or s/c. Talk to these guys http://advancedinduction.com/
Old May 5, 2011 | 10:40 PM
would it be safe to run flat top pistons, nice heads cam intake and like a 150 shot ? in your opinion? (full bolt ons along with that)
Old May 5, 2011 | 10:56 PM
MachinistOne's Avatar
Yes, have the rods re-sized with ARP bolts...although cost wise that's almost as much as upgrading to some Scat Pro-I beam rods.
The crank will be fine, and the stock rods will live with a light piston, no putting in heavy TRW/speed pro slugs and expecting to spin 7k for 500hp.
Balancing is a necessity.
Old May 5, 2011 | 11:03 PM
okay i was looking at the pistons in the link below. i figured they would work with the set up but new to lt1s so give advice. also machinistone can you send a link of the scat rods you mentioned? just to make sure im looking at the same thing. thanks
http://www.summitracing.com/parts/UEM-1489HC-STD/
Old May 5, 2011 | 11:22 PM
henryz28's Avatar
These are what I am using http://www.probeindustries.com/Chevy...ns_p/12334.htm they will good for nitrous, but you need lower compression for s/c.
Old May 5, 2011 | 11:39 PM
ill keep them in mind. would if be safe to put a 150 shot to the pistons i put in the link above? (there arent forged.)
i have another question. to start i have no idea what im talking about when it comes to head porting but i was reading old threads and noticed the stock heads can be ported to suport 500 hp. what kind of numbers do i need to tell the machine shop to get a price? i wanted it tobe streetable but not a daily driver. so whats a good cam aswell . not sure ifi should adress a cam now so it can match head work or what not.
as far as asking aboutthe port numbers.
what should the intake ports or runners w.e theyere called be, valve jobs or anything else i missed.
thanks again for the help.
Old May 5, 2011 | 11:57 PM
henryz28's Avatar
Stay with http://elliottsportworks.com/ or http://advancedinduction.com/ for the heads and cam; you will not be disappointed by either one, but advancedinduction is CNC work. I would not put 150 shot to those keith black pistons, and I really would not even run them with a good h/c set up. You can get a lot of info about building a lt1 from either of the head porters I posted up, they also do custom grind cams. Those pistons I posted are not too expensive http://cgi.ebay.com/ebaymotors/SBC-S...Q5fAccessories
But you will need to order piston rings also the Sealed Power Hellfire Piston Ring are supposedly good for nsx.
Old May 6, 2011 | 12:21 AM
okay man thanks for the info.
Old May 6, 2011 | 01:32 AM
These are the rods I use:
http://www.jegs.com/i/Scat/942/26000...oductId=761557
To choose pistons you need to make the choice now about which way you want to go power wise, if you are going to use a S/C you need to run a lower compression piston.
Old May 6, 2011 | 01:49 AM
Fatdog2's Avatar
I heared the auto trans can only take about 400 ponies.Don't forget the rest of the setup.My02
Old May 6, 2011 | 11:05 AM
its a 6 speed. but thanks.
oldschool
Feb 9, 2016 09:21 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Nov 20, 2014 06:03 PM
1LEThumper
Jul 14, 2003 12:45 PM
