LT1 speedometer tech Q.
Old Sep 10, 2004 | 11:44 AM
aaron_depue's Avatar
Can you swap out a 94 speedo. w/ 115 mph reed out to a speedo out of a 95 with 155 mph read out? Will it read the right numbers when you start it up? My speedometer only has 115 on the read out and I want the hihger mph read out cluster. Will it be a direct replacement? Please respond but i just dont have a clue
Old Sep 10, 2004 | 12:15 PM
Buttercup's Avatar
Re: LT1 speedometer tech Q.
Yes, you can swap them. The only thing I'm not up on is the legalities of it because of the odometer change.
Old Sep 10, 2004 | 12:54 PM
MILESF's Avatar
Talking Re: LT1 speedometer tech Q.
You can swap your old odometer also. It's a simple deal. Just many Torx screws and one electrical connection.
Old Sep 10, 2004 | 06:48 PM
Thanx. I appreciate the advice. Will a hypertech pp3 work? If so is it still the original car speedometer model of pp3? Replys would be appreciated
Old Sep 10, 2004 | 06:49 PM
Thanx. I appreciate the advice. Will the speedometer read correctly, also? Will a hypertech pp3 work? If so is it still the original car speedometer model of pp3? Replys would be appreciated
oldschool
Feb 9, 2016 09:21 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
FASTFATBOY
Jul 6, 2002 01:02 AM
