LT1 Solid Roller Cam valve lash?
What valve lash are you guys using on your solid roller cams? I purchased a used Cam Motions Solid Roller (242/252 .606/.606 108.9 LSA ) and it doesn't have a cam card. My engine machinist has checked it out and it's fine but I would like to know what lash to run (even a ball park figure will do)
I emailed Cam Motions but no response.
Thanks!
Thanks!
actually i wouldnt believe its a cam that size but i called cam motions and they verified the specs. To be honest, i dont really drive my car that much. On an old cam only tune, the car will idle just fine after it warms up and i dont get any cam surge. There are times that the car will die but it doesnt happen that often. I need to get it tuned and get a new clutch, then head off to the track.
95chwagon
Jan 13, 2015 09:19 PM
