LT1 shortblock questions
Old Jul 27, 2008 | 10:29 PM
97'Z-28's Avatar
Question LT1 shortblock questions
Hi all, Last friday I spun a bearing on my 95 Z28,
click here for info.
So I've decided against a rebuild since I think this car is not worth it, I have always wanted a 97' Z28.
I want to call junk yards in town to see if I can find a good used lt1 shortblock, swap the block, sell the car and buy a 97'.
The main question is: can I use an LT1 block out of an other car?
If so, what other cars came with an LT1?
Thanks in Advance
Old Jul 27, 2008 | 10:43 PM
97SS0594's Avatar
you do know that your car is almost identical in every way to a 97, all except the interior. and yes you can use any lt1 block in any lt1 car, my 97SS currently has the motor out of my 95Z28 in it. oh and your car has less headaches than a 97...
Old Jul 28, 2008 | 09:49 AM
camaro1fastz28's Avatar
u can use the shortblock out of a carprice or fleetwood they are normal alot cheeper and just get a gasket set and mount ur head on it
Old Jul 28, 2008 | 02:06 PM
RallyBoy1's Avatar
Man, I would probably just keep the 95 because it is obd1. Plus you only have to deal with one catalytic converter instead of two.
Old Jul 28, 2008 | 02:13 PM
ulakovic22's Avatar
Swapping the short block out and using all your 95 stuff on it will work fine.
Old Jul 28, 2008 | 04:41 PM
97'Z-28's Avatar
Like what?
The only reason I want a 97 is because of the 30th aniversary, and the new dash style.
I thought obd2 was better for tuning??
do 96-97 really have 285hp instead of 275?
Old Jul 28, 2008 | 04:44 PM
97'Z-28's Avatar
what year caprice or fleetwood?
would I be able to use the same 95' optispark?
Old Jul 28, 2008 | 09:22 PM
97SS0594's Avatar
if your looking for a white 97 with the stripe package, you know a true 30th thats cool but if you just want any 97 to call it a 30th, thats just being a poser. and you can use any motor out of a roadmaster or a fleetwood as long as its a 5.7 LT1 i say 5.7 because there are some of those big bodied cars that have a 4.3liter LT1 in them.
oldschool
Feb 9, 2016 09:21 PM
cmdeshon
Dec 27, 2014 10:06 AM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
Queens94z28
Nov 20, 2014 06:03 PM
Camaro90RS
Jul 23, 2002 07:57 AM
