LT1 Scanmaster Install
Old Aug 1, 2003 | 02:04 PM
Rice-X's Avatar
Just got my scanmaster in the mail today. I'm planning on installing it in the a/c vent. I've got the instrutions from online and they don't look too difficult. What i would like to know is how long did it take your guys to install it yourselfs in the vent, is it a fairly easy and smooth install? Any precautions or anything i shoud know before i rip my dash apart. Thanks in advance
Old Aug 1, 2003 | 02:57 PM
BPS's Avatar
BPS
sounds like we have similar setups.
It took me a couple of hours to install, it's very straightforward and Brents instructions are very good, Just take your time.
I fitted a spade end to the white(grey) wire and insert that into my ecm plug, that way when I program my car or log a run I have to remove it, some folks hardwire it in but the scanmaster and other logging software can not be run simultaneously, so either put in a switch or a spade bit on the wire to the ecm plug.
Old Aug 1, 2003 | 03:35 PM
Kain's Avatar
Took me a couple hours, I was aided in that I already took the dash apart once to transplant my stereo from my old Suburban into the Z28. IMO, I'd get a friend to keep you company while you work.
Also I'd use a bit of electrical tape around the Scanmaster and where you put it, there was a light back there and it seeped through past the Scanmaster. It bugged me so I taped up all the places I saw light coming through from behind the dash.
Old Aug 1, 2003 | 09:37 PM
Eliminator's Avatar
What all can you do with scanmaster and how much does it cost?
Old Aug 1, 2003 | 09:45 PM
Z95m6's Avatar
i would recommend you get a plug in connector for your car from akmcables. I think it was only like 10 bucks then you don't have to butcher your wiring and you can unplug it when you need to tune.
thenewkid
Nov 29, 2014 04:54 PM
Rich_z28
Sep 13, 2002 03:35 PM
Rich_z28
Sep 8, 2002 12:00 AM
Rich_z28
Aug 27, 2002 12:20 AM
