Lt1 rebuild qustions
Old Oct 11, 2011 | 08:27 PM
  #16
jaben2's Avatar
Re: Lt1 rebuild qustions
well I am going start pricing some items. I am worried that if I go the route of the cam and heads, and hit my 400, it won't be long I will probably want to go bigger.
I am going to talk to the builders next week. See what kinda of ideas they have. Run some numbers and see what price range I am going to be looking at. I am thinking if it will only be the matter of a different crank, and rods, guessing another $1000, I may as well go with the 383.
It will depend on cost I guess, and see if I can justify it.
Thanks,
Old Oct 11, 2011 | 09:18 PM
  #17
dennis5374's Avatar
Go forged for sure man. Reliability is the main thing. You can build one good motor for less than the price of two bad ones.
Old Oct 12, 2011 | 01:40 AM
  #18
henryz28's Avatar
If you think you may want to go big on the heads and cam, then yes a forged 383 will be your best bet. Don't let your builder talk you into a $250 cast crank; they like to fall apart, my builder tried to talk me into a cast crank when I looked around his shop and noticed two motors with broken aftermarket cast cranks I decided to keep my stock crank. Go with something like this
Crank - Scat 4340 3.75" 1pc rms
Rods - Scat 4340 6" Procomp I beams
Pistons - Mahle coated forged with rings and wristpins
Bearings - Clevite coated H series rod and main bearings
Old Oct 12, 2011 | 07:34 PM
  #19
Makin' Do's Avatar
I am about to start a rebuild of my own and I have been thinking about the same choices. So is the LT1 bottom end special or will any SBC rotating assembly work? Also, has anyone used the splayed 4 bold mains? Is it worth the price and machining?
Old Oct 12, 2011 | 09:05 PM
  #20
RamAir95TA's Avatar
The stock bottom end is typical SBC with a one-piece RMS.
The stock 2-bolt mains are very strong and can support some big HP.
Old Oct 13, 2011 | 09:28 AM
  #21
dennis5374's Avatar
Also the stock crank can handle some major abuse as well. Don't buy an after market cast crank, the stock crank is suitable for a 500 fwhp motor but if you have the extra coin then 600-700 is minor for the insurance a 4340 crank will bring.
Old Oct 15, 2011 | 05:19 PM
  #22
camz28ryan's Avatar
Don't mean to change the subject but can you get a motor balanced after its installed in car?
Old Oct 15, 2011 | 05:49 PM
  #23
bw_hunter's Avatar
No. Balancing requires the crank to be in a jig, spun with weights attached to the rod journals.....
Sergio
Jan 27, 2016 04:27 PM
Vinceocratic
Jan 26, 2015 09:26 AM
Not Dave
Dec 11, 2014 06:32 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
