lt1 rebuild
Old Feb 5, 2014 | 07:51 AM
lilrob's Avatar
lt1 rebuild
i have a 1994 z28 with 2xx,xxx miles on it... im looking to have the motor rebuilt... prob bored to 355... i have a shop in mind to do the work but i dont know what parts are needed... i dont want to get taken to the bank on this build... i have head and cam in mind... (le heads lt le2 heads and custom grind cam) arp bolts. other than that i dont know what else is needed............plz help??????????
looking for about 350-400 rwhp
Old Feb 5, 2014 | 05:06 PM
Kevin Blown 95 TA's Avatar
Re: lt1 rebuild
So you need new pistons and rings, seals, gaskets, bearings freeze plugs - get a new oil pump and maybe a steel shaft to drive it. Besides your heads and cam, you will need at least new valve springs if they don't come on the heads, and you should get some good roller rocker arms, rocker arm studs, and probably pushrods. You will have the choice between self-aligning rocker arms and non self-aligning which need guide plates which is probably the best way to go. You will probably have your crank polished and the rods resized after installing good rod bolts. The crank might need to be rebalanced. You will need head bolts and may want to consider main studs also. Other stuff - maybe a new water pump and optispark distributor. You might need some tuning of the PCM unless the cam is really small. It adds up quick and that is just a basic list.
Sergio
Jan 27, 2016 04:27 PM
Vinceocratic
Jan 26, 2015 09:26 AM
Not Dave
Dec 11, 2014 06:32 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
