lt1 question
Old May 4, 2011 | 05:07 PM
camaroblazing's Avatar
lt1 question
I got a lt1 that im building back up but i got it out of a carprice and putting it into my 96 camaro is there anything that I need to change other then the basics like trans and rear diff? also im having trouble remembering where all the intake manfold bolts go i know where the alternator botl goes but other than that does it matter? also is there a big diff in horspower and if yes what i need to change in it to get more out of it cams? heads?
Old May 4, 2011 | 05:36 PM
Re: lt1 question
Courtesy of Shoebox:
http://shbox.com/ci/intake_bolts.jpg
Are you sure the Caprice engine is an LT1 and not a 265ci L99?
http://www.lt1.org/lt1tech.html
If it is an LT1 from a Caprice, it will have iron heads, lower compression ratio and a different cam. The iron heads actually flow better than the LT1 aluminum heads. The engine has a lower HP rating, but its got nice low end torque.
oldschool
Feb 9, 2016 09:21 PM
cmdeshon
Dec 27, 2014 10:06 AM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
Camaro90RS
Jul 23, 2002 07:57 AM
