lt1 question
Old Sep 4, 2009 | 07:08 PM
Garylisko's Avatar
lt1 question
i just replaced the cap and rotor its all new but after that i drove it and the water pump went so i replaced it and put new gaskets on wiped off everything including the cap and rotor my question is although the cap and rotor is new and i just replaced the water pump can the cap and rotor still go bad even though its new?
Old Sep 4, 2009 | 07:12 PM
Z-RATED94's Avatar
It's hit or miss. I wouldn't worry about it though. It's not as fragile as many make it out to be, when it comes to getting wet.
Old Sep 4, 2009 | 09:01 PM
Spartan7's Avatar
It should be good if you caught it right away. Moisture really has to soak in to start arcing inside the cap. I would open it up and make sure it's dry on the inside, just to make sure.
Old Sep 4, 2009 | 09:20 PM
bw_hunter's Avatar
Water isn't too much of a problem but antifreeze is. I'd recommend removing and cleaning it inside and out and then saturating it WD-40 or CRC 5-56. Then it'll be as good as it can be.....
oldschool
Feb 9, 2016 09:21 PM
cmdeshon
Dec 27, 2014 10:06 AM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
Camaro90RS
Jul 23, 2002 07:57 AM
