LT1 question
LT1 question
Whats the difference between the LT1 in the caprice's and the LT1 in the F-Body. All i know is that the caprice has cast iron heads resulting in a 15hp drop. Do the still have hardened pushrods, any big differences that could cause problems with a head/cam install?
Re: LT1 question
Right now i have a caprice lt1 in my car cuz the original owner blew the motor by not upgrading to double valve spring with the cc305. I heard 93-95 Fbodies had hardened pushrods. the caprice heads flow better? so should i get those port and polished or should i do the stock alum heads?
Re: LT1 question
The b-body got hardened pushrods the same years the f-body did
Re: LT1 question
Originally Posted by 96capricemgr
As noted those iron heads you are so convinced are bad flow MORE than your aluminums. The HP drop is due to a more torque targetted cam, restrictive intake and exhaust, and 87 octane. While it may be down on peak hp a little it make more torque at a lower rpm EXACTLY what the b-body needed..
oldschool
Feb 9, 2016 09:21 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
Camaro90RS
Jul 23, 2002 07:57 AM
