Holley throttle body
Old Jan 8, 2006 | 08:27 PM
RICEFEDZ28's Avatar
Does anyone know if I need to have pcm programed to add a larger throttle body on an automatic trans car? I put it on once before and it caused my trans to shift really late and stay in 2nd. I put stock one back on and everything is fine. Is there something special needed to be adjusted? Any help would be great.
Old Jan 8, 2006 | 09:45 PM
LJ93Z28GM's Avatar
Re: Holley throttle body
Likely your TPS is not set correctly you need to open up the mounting holes so you can adjust it and check the voltage at idle and WOT by checking the wires that fed the sensor.
Your car might believe it is not at WOT even when you are. The car believes the pedal is in a different spot than it actually is. Most common problem on them. Had to do it on mine. Not hard to do at all just need a meter and some of your time and patience.
At idle it needs to be at .3 to .9 volts in the middle is best some years will throw a code or do odd things as yours. WOT is suposed to be about 4.8-5.0 volts.
Old Jan 25, 2006 | 10:02 PM
plan Z's Avatar
i'm having kind of the same problem. i've been trying to adjust my tps everywhere (from .4 - 1.0 v) and most of the time my problem is its shifting way too early. once or twice i got it to do the opposite and shift late like you are. but then when i readjust it back a little, it shifts too low again. when i had it set at 1.0 v, the tps% was actually 1% though so i guess thats too high. can i adjust any of the tables when tuning my car for the torque converter engage/disengage and the shift points? should i just set the tps to like .6 or .7 and then try to start tuning?
Potent77
Mar 16, 2022 12:13 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
warmeck
May 1, 2015 11:30 AM
Queens94z28
Dec 20, 2014 09:11 PM
