LT1 Power
LT1 Power
Hey guys girls fellow camaro owners.. Anyone have any ideas on some quick easy performance. its an LT1 it has a full cold air, im about to put my ecu on and i dont know what all else. any ideas text me at 7653187625 or leave a comment Later guys thanx for the ideas
Re: LT1 Power
If you haven't already, make sure all the maintenence is upto par. A LT1 running optimal before modifications is priority. Then headers, exhaust, tune will make quite the difference if your on a tight budget.
Re: LT1 Power
In order to get usefull info, you need to provide basic data about the car, particularly the year and trans type. Not all years of the LT1 engine are the same, and the mods for a car with the 4-speed automatic ("A4") will be different than the mods for the 6-speed manual ("M6") in some cases.
You also need to clarify what you mean by "im about to put my ecu on". Are you replacing the computer ("ECM" in 93; "PCM" 94-97)?
Why not add a "Signature" with basic info about your car - year, model, engine, trans and any major mods? That way the info will be included at the botom of every post and you won't have to type it over and over.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
