LT1 Plate **Group Purchase**
Old Apr 19, 2007 | 04:06 AM
  #31
94CamaroZ28's Avatar
Originally Posted by Ray@NitroDaves
A single nozzle will make approx. the same power....our plate kit gives you 8 discharge ports compared to one...this helps to improve the atomization and therefore gives you slightly better distribution. It also will give you a cleaner install over a nozzle.
Ok, but this kit still relies on the intake to do it's job; in other words, unequal distribution due to the intake is still an issue.
Hope this item will continue to be a stock item; I know my local CNC guy could afford to keep turning them out pretty easily at the price you get for the plate, a couple bolts, and a gasket that comes with the conversion once the program was stored.
It's too bad you didn't have the fuel and N2O come in across the bore from each other; seems that would give even better mixing and atomization.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
Chet1185
Feb 4, 2015 09:51 PM
ddr698
Jan 9, 2015 10:05 AM
heavenly_six
Dec 10, 2014 12:23 AM
