Lt1 overheating?
Old Aug 14, 2007 | 09:21 PM
henryz28's Avatar
Lt1 overheating?
Hay guys my car is a 96 z28 full boltons and Hot cam.For some reasion its like the electric watter pump stops working. Whial driving; next thing I know the car starts to heat up passed 1/2 way so I pull over and pop the hood. The first thing I noticed is water is dumping out of the overflow tank.What could be causing this problam? I think the waterpump is wired up wrong, how did you guys wire your waterpumps?Thanks
Old Aug 16, 2007 | 03:08 PM
CCRJon's Avatar
make sure that the fans are coming on at their stock programmed temps. I had the problem for a few months - that if my car would sit at a light - the temp would rise like a rocket. Once I started moving - it went back down again. I heard the high speed fan on always. However, the low speed fan had a bad relay. It never came on until i replaced the relay.
I had the same thing happening - gushing out of the overflow tank! Man that sucked.
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
