LT1 optispark cover
Old Nov 17, 2004 | 09:31 PM
wicked cmr's Avatar
LT1 optispark cover
Hey guys, i am using a rear mounting distributor on my lt1 instead of the optispark, and i was told i need a plate to cover where the opti use to be, i have a part # 12367600 for one, but the part description on gmpartsdirect.com states the following : This cover / plug is used to cover the hole on the front cover of a 1996 LT4 engine when the distributor is removed and a rear mounted distributor is used. Anyone know if this will work with most lt1 blocks, or is it only for the LT4, or do i have the wrong part #? Thanks.
Old Nov 19, 2004 | 07:44 PM
wicked cmr's Avatar
Re: LT1 optispark cover
anyone know please? got my car in the shop right now and i told them i'd order it since i guess its not a regular part , thanks any info is greatly appreciated
Old Nov 19, 2004 | 11:03 PM
Scotts94z28's Avatar
Your info is somewhat vague, but I am assuming that you could just use a old opticrap as a cover. Of course the drive gear would still need to be installed to seal off the front cover it that respect. Maybe look into that, remove the opti rotor, obviously not hook any eletrical to it and just use the stock unit.
Trying to remember what all is involved between the opti and the timing cover. Hope this might help.
Old Nov 19, 2004 | 11:23 PM
wicked cmr's Avatar
yeah i spose that would work hehe, i just wanted it to look as clean as possible , and i dont have an opti to put there right now, im using HEI . i spose i can buy a broken opti and just use the back plate lol, but id really like to have the one made for it for this distributor conversion. opti to hei.
Thanks the info did help, all info helps
Old Nov 19, 2004 | 11:45 PM
hosspwr94's Avatar
All that needs to be covered is the hole where the distributor drive goes through the front cover. I am not sure of that part number but its not that big of a piece you could have the front cover modified to plug that hole. Just my .02 Good luck!
What do you have this is in? prolly not an f-bod since you are somehow fitting a distributor under a cowl.
Old Nov 19, 2004 | 11:56 PM
Lonnie Pavtis's Avatar
Yes you have the correct part. It will work on any '95 up LT1 or LT4 engine.
Old Nov 20, 2004 | 12:33 AM
wicked cmr's Avatar
excellent thanks guys, Yah its in a 83 camaro with a 4" cowl hood
HectorM52
Jan 30, 2015 11:34 PM
ddr698
Jan 9, 2015 10:05 AM
Injuneer
Dec 15, 2014 09:36 AM
Jul 4, 2005 05:00 PM
