LT1 Oil Pressure Sensor Screen
Hi All,
I am pretty sure the answer is no, but I have been told that the 5.7 LT1 engines have a screen located below the oil pressure sensor and it should be changed if the oil pressure sensor is replaced. I cannot find any reference to an oil pressure screen part anywhere for the LT1 engine. Am I missing something?
Thanks!
Thanks!
Re: LT1 Oil Pressure Sensor Screen
Sounds more like something used on some of the LSx engines (trucks?). Not aware of one on the LT1. Given the location of the (94-97) port and the elbows required to connect the sensor, hard to see how you would even access the port with a filter.
http://shbox.com/1/op_sensor.jpg
