oil pressure sending unit
Re: oil pressure sending unit
Originally Posted by Mystic97Z
hey, what year lt1 oil pans have the low oil pressure sending unit, and what years do not?
You've got that confused. The sensor in the oil pan is the low oil sensor, not the low oil pressure sensor. The oil pressure sensor is located at the top back of the block on 94+s, and on the driver side middle/back of the block on 93s.
All year LT1s have the low oil sensor on the oil pan.
All years oil pans have the low oil level sensor. On the drivers side, big as hell, you can't miss it. If it's not on there, I would question the engine as it's either been rebuilt with the wrong pan, or it's not an LT-1.
-Shannon
-Shannon
