LT1 Oil pan torque sequence..!
Old Jan 19, 2006 | 01:31 PM
AlmostfastLT1's Avatar
Anyone have a diagram of the oil pan torque sequence for a stock oil pan on a LT1 camaro...
Thanks Mark need asap!!!
Old Jan 19, 2006 | 02:04 PM
96m6lt1's Avatar
Re: LT1 Oil pan torque sequence..!
if you go from the inside out top and bottom you will be fine,these gaskets have metal sleeves in them to keep you from pinching gaskets.
Old Jan 19, 2006 | 02:08 PM
Digital Designs's Avatar
work in a clockwise motion from the middle out to the ends torque is 10ftlb , do not forget the metal rails that sandwich between the pan and bolts.
Old Jan 24, 2006 | 09:42 PM
anyone have the torque sequence...???
Old Jan 24, 2006 | 10:26 PM
1racerdude's Avatar
Yea-- start at the first bolt on the drivers side,tighten with 3/8 drive then go to the next one on the opposite side continue until all are tight.
Just tight-- there is no sequence per say.
HectorM52
Jul 30, 2017 11:46 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
Elcojoe
Nov 17, 2014 10:27 PM
