LT1 MSD Cap and Rotor - Yes I GOT ONE!!
Old Nov 8, 2005 | 05:45 PM
  #16
Rage's Avatar
Re: LT1 MSD Cap and Rotor - Yes I GOT ONE!!
How much is the complete unit? And what would be the benefit to purchasing this as opposed to a stock opti-spark?
Old Nov 8, 2005 | 06:21 PM
  #17
jsetzer's Avatar
Looks nice but I am waiting for the msd lt1 distributor due out soon.
Old Nov 8, 2005 | 06:23 PM
  #18
turbo_Z's Avatar
Not to burst anyones bubble here but if you rip appart a good opti to install an MSD cap then you are wasting your money.
Old Nov 8, 2005 | 06:25 PM
  #19
Z28barnett's Avatar
Have you heard any dates for the release?
Z28
Old Nov 8, 2005 | 06:39 PM
  #20
Rage's Avatar
Does anyone have a link to some information on the entire MSD Opti-spark setup? I cannot find anything in the entire world (wide web) that says anything about it.
Old Nov 8, 2005 | 06:44 PM
  #21
kick Z tail out's Avatar
Thumbs up Re: LT1 MSD Cap and Rotor - Yes I GOT ONE!!
Yeah I've been eyeing one for my upcoming tune up... Very cool.
Old Nov 8, 2005 | 06:58 PM
  #22
V8 Slayer's Avatar
I have an MSD Cap/Rotor on my '91 V6 Firebird
Old Nov 8, 2005 | 07:16 PM
  #23
hsyr's Avatar
http://www.msdignition.com/2006/06-4.htm
I posted the link on the first page of this thread also. You might have to call for a price though
Old Nov 8, 2005 | 08:48 PM
  #24
LJ93Z28GM's Avatar
I could not find a price either but I am guessing around $500 just read what is lists as upgraded over stock.
Would like to know how they are adjusting timing +/- 5 degrees
Pro-Billet™ LT-1 Distributor
❚ Advanced optical encoder trigger design for accuracy and reliability.
❚ Easily adjust the timing up to +/-5°.
❚ Improved housing design and extra bolt eliminates leaks.
❚ Fresh air vented and sealed to keep the elements out.
❚ Large ball bearing stabilizes timing through 10,000 rpm.
❚ Rotor drive design is positively indexed and cannot slip.
Finally, an all-out performance distributor to replace the OEM GM LT-1 Optispark! We machine an entire billet block of aluminum down into a precise housing that fits in place of the factory piece. Then, we fill it with a reliable new pickup assembly, a trick timing adjustment mechanism and top it off with an all new MSD distributor cap!
The pickup is an advanced optical encoder, a different style of optical pickup than the OEM. This style pickup has proven to be very reliable and stable through extreme rpm and conditions. The rotor is bolted to a drive assembly that is indexed to the shaft and is stabilized through the use of a large ball bearing assembly.
Once installed, you have the ability to adjust the ignition timing – the only distributor that offers timing adjustability! An adjustment screw allows the timing to be tweaked up to +/-5°. The distributor is equipped with a fresh air vent and has an extra thick mounting surface for the cap to eliminate leaks.
The distributor is supplied complete with our heavy duty LT-1 Cap, Rotor and the components required for installation.
Pro-Billet LT-1 Distributor
’94-’96 Late Model PN 83811
’92-’94 Early Model, supplied with fresh air hoses PN 8381
Old Nov 21, 2005 | 01:45 PM
  #25
SweetZRag's Avatar
Summit is advertising them for $499 with an estimate ship date of 12/19/05.
P/N MSD-8381 (Non-vented)
P/N MSD-83811 (Vented)
One question. The Non-vented unit says it comes with hoses. What are the hoses for if the unit is non-vented? Anybody know?
Old Nov 21, 2005 | 02:40 PM
  #26
kgkern01's Avatar
I think it converts it to a vented unit. At least thats what I got from reading it.
I will be needing a new optispark soon (100k) on the current one and would like to upgrade to the full MSD opti unit.
Old Nov 21, 2005 | 03:18 PM
  #27
SweetZRag's Avatar
I would think that if you were converting, you would just buy the 83811 since it is vented. Since the 8381 is nonvented, what would the hoses connect to? I hope MSD clarifies. If anybody finds out, please update us
Old Nov 21, 2005 | 03:41 PM
  #28
Mean Green's Avatar
Word
there's nothing wrong with the stock cap and rotor, those never fail. if i still had it, i'd show you my 134,000 mile opti that was factory original AND still worked fine and contacts were still in good condition.
i could understand upgrading the actual optical sensor, but around $500 a pop (rumored MSRP) i'd rather go with a delteq and have less of a headache with the thing getting wet or dirty from it's less than desirble location.
Old Nov 21, 2005 | 04:15 PM
  #29
SweetZRag's Avatar
Originally Posted by Mean Green
Word
I can see the performance improvement from the Delteq but I can't see the reliability improvement since it is still relying on the optical sensor for its timing input. In my case, I have had 2 GM optisparks fail due to the optical sensor failing. What I don't know for sure is if the optical sensor itself failed or if it actually was blocked by rust residue from the bearing failing. I hear that the bearing (bushing?) is actually a very common failure point. If the MSD has an improved bearing, maybe we won't see so many optical sensors getting damaged (or blocked) by the residue of a failing bearing.
Old Nov 21, 2005 | 04:24 PM
  #30
rock1501's Avatar
MSD-83811 DISTRIBUTOR $499.95 $499.95
·This part is temporarily out of stock, but you can order it now. Tentative ship date: 12/22/2005, if your order is placed today.
I think I will order one for sure I like the timing retard feature plus the construction looks solid
