Lt1 motor Swap
Old Mar 11, 2012 | 04:39 PM
lt1le2's Avatar
Lt1 motor Swap
Will a 96 imapla ss lte motor fit in a 95 z28 for a swap
Old Mar 11, 2012 | 05:27 PM
dennis5374's Avatar
Re: Lt1 motor Swap
Its another lt1 right? I'm sure it will fit if so. If its an iron headed motor though I would swap the aluminum heads onto it. May be little miniscule differences like where stuff plugs in an such but shouldn't be a difficult swap at all.
Old Mar 11, 2012 | 11:05 PM
andssrew1990's Avatar
Re: Lt1 motor Swap
Im in the process of actually putting a l99 4.3l out of a caprice in a 94 formula. Engine swap should be near identical.
Problems I have ran into so far would be just the accessory bracket. Most people seem to just swap the Hub damper but Im having a custom spacer and bolts made from a friend whos a machine operator.
Other than that, it seems like it is all plug and play. Only thing I see that might cause a small issue is the style of opti thats on it.
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
InfernalVortex
Jan 17, 2015 09:35 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Ricardo
Nov 29, 2014 10:58 AM
