LT1 Motor Mounts?
Old May 28, 2007 | 07:54 PM
SentimentalValue's Avatar
LT1 Motor Mounts?
I just bought the $50 set poly motor mounts from Spohn and 2 poly mounts came in, but they are different sizes / dimensions. Are these the motor mounts for both sides (they just have different dimensions) or should I have ordered two sets?
Thanks.
Old May 28, 2007 | 08:03 PM
wrd1972's Avatar
The driver side mount is very funky shapped, almost like a triangle. The right side is very similar to the normal SBC mount but has different bolt alignment that makes it cost more than 4X the normal SBC mount.
Old May 28, 2007 | 09:50 PM
2QUIK6's Avatar
When I got mine, it was just the poly part, I had to drill out the rivets in the mount clam shell and reuse them with supplied nuts/bolts to bolt the clam shells back together.
HectorM52
Jul 30, 2017 11:46 AM
willismoons
Feb 14, 2015 08:42 PM
1LEThumper
Jul 14, 2003 12:45 PM
