lt1 miss and popping exhaust
Old Dec 30, 2012 | 07:47 PM
  #31
jklopez09's Avatar
Re: lt1 miss and popping exhaust
Stock injectors and fpr. Not sure about pump. I bought it as is
Old Dec 31, 2012 | 06:16 PM
  #32
jklopez09's Avatar
Could this high fuel pressure be causing a random miss? If i have stock injectors and fuel pressure regulator, what could cause the high pressure? Thanks in advance for the help.
Old Dec 31, 2012 | 06:56 PM
  #33
slick1hunting's Avatar
I have racetronix pump and hotwire kit and stop fpr and im at 50 but my tune is setup around that pressure for my larger injectors. My guess you may not have stock pump and may have hotwire kit also. If your tune isnt in line with your high pressure I would guess would be a problem(might not be the problem). Id look at a couple plugs that are easy to pull til someone gives you better advice than I have.
AdsoYo
May 2, 2018 03:21 AM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
JSK333
Sep 9, 2002 10:33 PM
