lt1 maximun chamber cc's ??
Old Feb 18, 2006 | 07:34 PM
89gmc's Avatar
Exclamation lt1 maximun chamber cc's ??
Tried searching but search didn't turn up anything. I'm stroking a lt1 to 383 and would like to open up the chamber some to lower the compression ratio. What is the largest that this chamber can be opened up safely ??
Old Feb 18, 2006 | 07:36 PM
Dave89IROC's Avatar
Re: lt1 maximun chamber cc's ??
why not just get the correct pistons(you need them anyway) to get the CR you desire?
Old Feb 18, 2006 | 08:07 PM
89gmc's Avatar
On this particular motor I am using -12.5 cc dish pistons and I am planning to deck the block so i have about .038 piston to head clearance. According to my calculations that will put me right at 11 cr. and I wanted to back it down a little to about 10.5 cr. Also I recently picked up a 400 and I was thinking of doing the conversion of the lt1 head which involves welding up the 4 corner holes so it can be used on a gen 1 block . Check out lt1.com for all the details. lt1 heads and intakes are going for dirt cheap but I would need a way to back down the cr on the 400 also. I know this is probably a little more work but I dont mind . http://web.camaross.com/forums/images/smilies/smile.gif
Old Feb 18, 2006 | 10:28 PM
96capricemgr's Avatar
I would probably look at Trickflows before trying to hog signifigant material out of stock chambers.
Old Feb 19, 2006 | 10:07 PM
Lonnie Pavtis's Avatar
I routinely use factory LT1 heads modified to 64-65cc for many of the supercharged motors I build.
Old Feb 19, 2006 | 10:30 PM
SStrokerAce's Avatar
I thought we mentioned some of these things on that other board!!!!
Don't lower it past 11:1!
Old Feb 20, 2006 | 12:33 AM
1racerdude's Avatar
Ya back it down much more than 11-1 and it will run like a t***. Your cam will tell ya what compression to run to get your DCR in the 8.5-9.0 range.
But it's your engine.
Old Feb 20, 2006 | 06:25 AM
I had guessed he was going boost from this response I take it that is not the case?
If staying NA then I have to agree keep the compression up.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Roadie
Feb 16, 2015 10:34 AM
95chwagon
Jan 13, 2015 09:19 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
