LT1 To LT4, worth it?
Old Jun 13, 2005 | 06:18 PM
  #16
hatredizm's Avatar
Re: LT1 To LT4, worth it?
Originally Posted by onlyone07
Jesus Christ, this questions been asked like eleventy billion times. USE THE SEARCH FEATURE FOR THE ANSWER!
How about you sit down, shut up, and shove another popcicle in your azz dude. Youre one of those ******** that are always shooting off at the mouth instead of helping people out. Enough said.
Old Jun 13, 2005 | 07:04 PM
  #17
chuckd4more's Avatar
Alright already. I know he was being a smatazz. As was I with my reply. I did a search and read alot. Sorry I asked. Sorry I'm new on here. I believe I am going to go with the LE2 setup.
Old Jun 13, 2005 | 07:22 PM
  #18
resurrectedz28's Avatar
I wonder how many lt4 topends out their there would be if we actually endorsed the idea. That settles it, Im going to help GM out and tell everyone to get one. (yeah I know there are better options, but the best way to learn about life is the hard way, woe to the next sucka who asks this).
Old Jun 13, 2005 | 07:44 PM
  #19
Quickshotkimber's Avatar
Make sure you check out everybody, Alot of my friends wish that they could go back and change thier first choice. You ought to figure out how fast you want to go and then look for ETs and the setups that they are running.
Old Jun 13, 2005 | 08:01 PM
  #20
onlyone07's Avatar
When I typed that I was sitting down, not speaking, and certainly not shoving anything up my ***.
Not true. I go out of my way to help people when I can. It's just when the same question is asked eleventy billion(see above posts) times in the past few weeks, it gets pretty repetitive.
Old Jun 13, 2005 | 09:22 PM
  #21
EviLZ28's Avatar
I have the LT4 conversion and The only reason I have it is because I got it for 1300 bucks. Would I pay the full amount? Never. I also had the heads ported as well as the intake because the intakes runners are puny when you get the intake new. I also added 30 svo injectors and a 52mm throttle body. Headers and all that other stuff that adds up quick. For someone to just buy the LT4 conversion and just bolt it on without any other mods or port work would be a serious waste of money and time. Like others have said on here. spend the money wiser and get better parts for less money then the LT4 kit.
Old Jun 14, 2005 | 12:20 AM
  #22
NewbieWar's Avatar
lol... Saturday night live...
gotta love it... I know kung foo
Old Jun 14, 2005 | 09:28 AM
  #23
hatredizm's Avatar
Well if the 'search feature' didnt bring up eleventy billions items that do not contribute to what you want to know, maybe more would use it. I definately dont use it cause I happen to think it sucks. I'll ask away and get an answer from someone who wants to help before I sort through a bunch of non-related crap.
Old Jun 14, 2005 | 09:30 AM
  #24
Antz97ZNJ's Avatar
this has been posted alot....general consensus is getting a much cheaper heads and cam package(like llyold elliot) will yield you way more power and be gentler on your pocketbook.
Old Jun 14, 2005 | 09:54 AM
  #25
NewbieWar's Avatar
hey i was thinking lt4 for a while, but now im thinking bigger and better... i got the general consensus that LT4 was a bad bang for the buck, so i plan to get a whole forged engine putting down about 500 tq and 480 hp...(flywheel)
now while chad recomends over at golenengines a 200 shot of N20 I am uncertain if i'll use that...
but after lyoid elliot recomended i get a crate motor from Golenengines i have started to save even more money
Old Jun 14, 2005 | 11:27 AM
  #26
Kurt Crosbie's Avatar
It's all about what you want. The lt1 has small intake runners, to make for more torque. All in all though, I believe the lt4 flows about 20cfm more, which would equate to a maximum NA horsepower potential of 40hp more (using the estimation of 2hp per cfm). However, like I said, the torque will be higher, which would keep the track times about the same. Is it worth it? Hell no. They use the same block. If you really want to, just get your heads ported slightly, port-match your intake, and you'll be set. That would cost you all of $500 maybe.
Old Jun 14, 2005 | 01:13 PM
  #27
Kraest's Avatar
Retired
Definetly not worth it unless you've reached the maximum potential of the LT1 casting stuff.
Mike
Old Jun 14, 2005 | 02:23 PM
  #28
And once you have reached the max potential of the Lt1 casting, you will not want just 20 more cfm. You probably go with some AFR castings or some 11* bowtie castings.
ModdedNerd
Jan 29, 2015 07:23 PM
Ken95Z28
Aug 21, 2002 04:32 PM
Skull Leader
Aug 10, 2002 11:01 AM
