Injector diagnostics?????
Old Jun 13, 2005 | 01:49 PM
JWS6's Avatar
Lightbulb Injector diagnostics?????
Yes I used the search button!!!!
When I turn the ignition to the on position I hear a hiss noise for 2 seconds after the fuel pump quits making its usual noise. The hiss is coming from the top of the intake area between the #1 and #3. This started after I blew a hose from my procharger to the intercooler. Do you think this is related.
Is this the sound of a bad injector o-ring??
TIA
Old Jun 13, 2005 | 04:49 PM
slopokrodrigez's Avatar
Re: Injector diagnostics?????
If you're talking about KOEO, no the problem won't be an O-ring since nothing has turned on the injector yet. Why don't you put a gage on the fuel rail to see what is happening to the pressure when you hear the hissing?
The nice thing about OBDII, if there is any, that you can turn off or turn on any injector with a scanner. My Snap-On CGS does it.
Old Jun 13, 2005 | 08:24 PM
JWS6's Avatar
the car does start and runs. Would this be a symptom of a blown o-ring? I do not have access to a guage at this time. thanks for the reply and nice punkin.
Old Jun 13, 2005 | 09:58 PM
ZMAN Z28's Avatar
You could pull the fuel rail, and disconnect your coil wire and have someone turn the key over and you could observe your injectors if there is any damage or something isn't normal.
Z
Old Jun 13, 2005 | 10:27 PM
JWS6's Avatar
I pulled the rail and inspected the drivers side o-rings. They all looked good but I replaced them since I was there. Is it normal to hear the fuel rail "fill up?"
Old Jun 14, 2005 | 02:33 PM
JWS6's Avatar
car runs good! starting new thread about odd sound. Thanks guys
93 RedBird
Nov 15, 2015 08:24 AM
form94
Sep 23, 2015 07:30 AM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
RubyRedIrocZ
3rd Gen / L98 Engine Tech
Sep 10, 2015 01:48 PM
plattted
West South Central
Sep 7, 2015 02:45 PM
