LT1 & LT4 corvette valve covers
Old Mar 12, 2008 | 11:46 AM
HottestZ28's Avatar
I was looking into the corvette black valve covers and found them new for 100 a piece through GM (but they are plastic?) I was told by the parts man
here are the part numbers can you tell me for sure?
R.H. 12552322
L.H. 12552321
Old Mar 12, 2008 | 12:09 PM
Kevin Blown 95 TA's Avatar
Yep - plastics -
http://paceperformance.com/index.asp...D&ProdID=22836
Old Mar 12, 2008 | 12:51 PM
HottestZ28's Avatar
are they plastic from the factory? or where can I get good ones
Old Mar 12, 2008 | 12:53 PM
They are composite, and they are very good ones. You will need studs and screws to hold them on, and a new oil filler cap too.
Old Mar 12, 2008 | 12:57 PM
95zsean's Avatar
They are a composite cover and they are the GOOD ones. You will have to modify them to get them to work with any other rocker arm than stock. Do a search that will help you find how to do that.
P.S. If you look at my link in my sig you will see a set of then, inow have a SS dress up kit on them.
Old Mar 12, 2008 | 01:11 PM
tireburnin's Avatar
I had the worst luck with the gaskets on the valve covers. Every time I pulled them off, the gasket would expand by like 3-4 inches. I ended up having to cut them down and attach them with RTV into the groove in the valve cover.
I have bad luck with simple things.
Old Mar 12, 2008 | 01:44 PM
HottestZ28's Avatar
will stock LT1 valve cover gaskets work with these? and thanks for the replys
Old Mar 12, 2008 | 02:17 PM
No, they will not. The composite covers normally come from GM with gaskets.
To install, you will also need:
8 of part # 10108675 bolt
8 of part # 10108674 stud
1 of part # 12555685 oil cap
Old Mar 12, 2008 | 02:19 PM
I run Comp Pro Mags under mine without modification or interference. That was one of the reasons I bought the covers in the first place.
Old Mar 12, 2008 | 03:07 PM
HottestZ28's Avatar
P.S. If you look at my link in my sig you will see a set of then, i now have a SS dress up kit on them.
Where can you get the dress up kits?
Old Mar 12, 2008 | 04:48 PM
SS RRR's Avatar
Considering Crane Golds were used with the LT4 and these valve covers that statement isn't really true.
Old Mar 12, 2008 | 05:27 PM
dangalla's Avatar
yeah that happens to me too.
a good trick to stop that is to "glue" the gasket into the valve cover with some weather stripping adheasive
Old Mar 12, 2008 | 07:19 PM
TheZ_project's Avatar
So what is the advantage of the composite VC's vs. stock LT1's?
Old Mar 12, 2008 | 07:25 PM
GreasyB's Avatar
Looks and I think they are a bit taller. Also no need for modification with RR's.
Old Mar 12, 2008 | 07:41 PM
SS RRR's Avatar
That happened to me and I really thought I was halucinating. I mean one minute they fit to size and the next they were obnoxiously long. I was able to place them back in the slots, but I have a feeling they are leaking on the rear corners. Not sure if they are the right size before applied and stretch with heat?
