LT1 to LT4 Conversion Question?
Old Feb 17, 2005 | 03:57 PM
  #16
TraceZ's Avatar
Re: LT1 to LT4 Conversion Question?
Originally Posted by steve9899
The LT4 hotcam can be used in any LT1/LT4. Dowel pin is adjustable.
What about the LT4 timing set? With that work with a non-vented opti too?
Old Feb 17, 2005 | 05:00 PM
  #17
sbs's Avatar
sbs
No. And it's not part of the conversion kit.
You might want to try searching as all this is FAQ.
Old Feb 17, 2005 | 10:34 PM
  #18
hektyk's Avatar
OK So I think I am going to go with the LE1 kit instead of the LT4. I will get that Longtubes, 52mm Throttle Body,CAI, MSD Ignition and the ECM custom Programmed. How Much Hp flywheel and Rear Wheel do you think I will run. Will it be more than the Lt4 kit, I know it will be cheaper and I can get more stuff.
LeftoverChinese
Jan 14, 2024 03:03 PM
MadMav
Feb 6, 2015 11:02 PM
Queens94z28
Dec 20, 2014 09:11 PM
Jul 4, 2005 05:00 PM
