LT1 > LT4 Accessory bracket alignment?
Old Nov 17, 2007 | 08:32 AM
1Z2Z's Avatar
I'm installing an LT4 engine (from a Corvette) into my 94Z. Although my LT1 accessory bracket for the Alternator and PS pump bolts right up, the LT4 has a dual mass damper on the crank that moves the serpentine belt out about 1 inch.
Questions:
-Did the Camaro / Firebird LT4s have a special bracket to adjust for this, or were spacers used to move the standard bracket out to match? Or was the standard damper used so bracket would line up normally?
-If the bracket is spaced out to line up the belt, it gets pretty tight for the lower two plug wires from that side of the optispark. I have not fit them up yet to see how bad, but looks like the straight boot would not be able to be installed. Is there a workaround to this?
Old Nov 17, 2007 | 09:27 AM
ChevalierSS's Avatar
Sounds like using an LT1 damper would be the easiest solution.
Old Nov 17, 2007 | 11:57 AM
I don't think the accessory spacing is the same, so you will likely need the Corvette crank hub and pulley.
Old Nov 17, 2007 | 12:12 PM
bingo's Avatar
I am running an f body hub with my Corvette accessories. They work fine. The balancer is definitely different. You can just switch the balancer.
HectorM52
Jul 30, 2017 11:46 AM
Hurin
Dec 13, 2014 07:38 PM
CaRParts102
Dec 6, 2014 08:45 AM
siguy
Nov 27, 2014 10:07 AM
thenewkid
Nov 27, 2014 09:41 AM
