LT1-->LT4
Old Oct 15, 2004 | 05:17 PM
mrLT4's Avatar
LT1-->LT4
I put a LT4 cam and 1:6 roller rockers in my LT1 and was wondering if it will make a big difference, and planning to put LT4 heads and intake but started with the cam
Old Oct 15, 2004 | 05:25 PM
Formula305fi's Avatar
Re: LT1-->LT4
ill tell you what every1 told me. its not worth the swap @ all.... lt4 heads ok, but the production lt4 cam is smaller then the lt1 cam.... imo not worth it, if u wanna do a small cam get the zz4 cam and throw that in there. im sure it will be better then the lt4...
Old Oct 15, 2004 | 06:13 PM
Red96Lt1's Avatar
Re: LT1-->LT4
If you get LT4 heads, you will have to get the intake to match. The entire LT4 swap is NOT woth the $$. Use that money and call comp cams and look at a cc305 cam or even the cc306. And port your LT1 castings. Lloyd Elliot does a great job and he can port match your heads to the cam you get. Please don't make the mistake of getting a LT4 set up.
football4life
Oct 4, 2015 07:48 AM
MDZ28
11
Sep 24, 2015 09:15 AM
sleeperZ96BT
Sep 9, 2015 08:28 AM
jackpawt883
Aug 26, 2015 11:22 AM
Cbr02
Parts Wanted
Aug 21, 2015 08:16 AM
