Lt1 ls1 swap
Old Jul 2, 2004 | 02:41 PM
smokindastangs's Avatar
Lt1 ls1 swap
I am seriously considering swapping out my Lt1 for an Ls1 and I have a few questions regarding this swap. Here are my questions: 1. will my transmission bolt up to an ls1?
2. will the a/c and power steering hook up to an ls1?
3. how much will a wiring harness cost?
4. am i delving into something that I will regret later?
Thanks for the help, Jason.
Old Jul 2, 2004 | 03:35 PM
Kain's Avatar
Easier to sell the car and get an LS1 car.
Old Jul 2, 2004 | 04:38 PM
Well I think that it would be much cheeper to get an LS1 engine than a complete LS1 car.
Old Jul 2, 2004 | 05:33 PM
1984camaroz28's Avatar
1 NO
2 NO
3 a painless about 500$
4 It depends
You will also need a LS1 Front K Member
Just build a 383 and smoke LS1 all day
Old Jul 2, 2004 | 06:52 PM
lovescamaros25's Avatar
i dont know why the transmission wont bolt up.
Old Jul 2, 2004 | 07:07 PM
because its a different bolt pattern....
Old Jul 2, 2004 | 09:26 PM
slp223's Avatar
what part of the tranny has a diffrent bolt patten? tranny to bell housing? the back of the engines have the same bolt pattern only an ls1 has one less hole.
Old Jul 2, 2004 | 10:06 PM
IrocSS85's Avatar
yes, the tranny will bolt up. he's right, one hole that is in our trannys is not there on the LS1. it will be fine. thats what all the big LS1 guys do when they bolt in a TH400. if those 8, 9, 10 sec. cars can get away w/o that one bolt, you'll be fine. you will need a diff. flexplate and conv. though. as well as all the accessories are diff. you will spend ALOT of money to make the swap. I think the only way it could be done and not spend a TON of money is if you bought a wrecked car that had all the stuff needed. if you piece it together, there's no way to account for all the little things you will have to get.
Old Jul 3, 2004 | 09:04 AM
i was told they make a a adapter plate
Old Jul 3, 2004 | 03:04 PM
slp223's Avatar
an adaptor plate to adapt what to what?
Old Jul 3, 2004 | 03:19 PM
Mindgame's Avatar
As far as I know you will need the following from an LSx car....
steering rack and steering linkage
k-member
electrical harness and PCM
radiator and fans
You also need more hood clearance (dunno what will work... maybe UltraZ??)
I don't know anyone who has done the swap so unless you can find someone, you're on your own. It's a good swap idea because of the potential but you may have some probs along the way. Getting through it is just a matter of your abilities/resources.
Good luck.
-Mindgame
Old Jul 3, 2004 | 03:30 PM
slp223's Avatar
here is one bet they could package the parts to do it.
http://www.hpsalvage.com/
Old Jul 3, 2004 | 04:24 PM
My friend told me that they make an adapter plate to use a turbo 400 or 350 trans with a LS1. But come to think of it hes kinda stupid
rocketman051894
Jan 30, 2015 03:23 PM
ddr698
Jan 9, 2015 10:05 AM
cmdeshon
Jan 4, 2015 11:15 AM
Jul 4, 2005 05:00 PM
