LT1/LS1 coil pack boot kit:
Old Feb 22, 2014 | 10:34 PM
Macs95LT1's Avatar
Waiting for my LTCC kit to arrive. I have Taylor 8mm wires on my car now. Is there a boot kit available so I can just use these to connect to the coils attached to stock valve covers? and...Is there a already assembled plug wire set that will fit this conversion? Figured this conversion has been out for a long time now, so maybe somebody designed a wire set.
Old Feb 22, 2014 | 10:53 PM
slick1hunting's Avatar
Re: LT1/LS1 coil pack boot kit:
I havent found any premade wires. You can order optispark ends to make custom lengths but your existing wires should have the correct ends and wohld be cheaper to get plug ends except I would prefer the new end at coil as boots often slip. If you can use a straight plug boot with your headers or manifolds the truck wires off 98(I think) up vehicles may work as they are longer than the fbodies.
Henson071
Sep 18, 2015 04:01 PM
Henson071
Aug 4, 2015 09:32 AM
detroitmuscle
Jul 31, 2015 04:21 AM
zajones
Jul 30, 2015 02:18 PM
asilomar244
Jul 12, 2015 05:53 AM
