lt1 issues
Old Jun 30, 2011 | 09:15 PM
sszcam's Avatar
lt1 issues
just got my LT1 tuned and am pretty disappointed. only put down 230hp and 250tq. from what i can tell this is at a min 50 hp low
89 camaro with 94 imp ss lt1 cc503 1.6 rr upgraded ls6 beehive springs comp lifters and pushrods. exhaust is shorties y to 3 " msd coil msd wires new plugs
why would this be so low???
Also under very slight acceleration the car spits and sputters
Old Jun 30, 2011 | 09:33 PM
Re: lt1 issues
Your last statement sounds like a clue. I wouldn't be wasting time on a dyno if it wasn't running right.
Old Jun 30, 2011 | 09:42 PM
sszcam's Avatar
Re: lt1 issues
thatswhy i took it to get tuned so it would run right...
does my issue sound like a spark issue or a sensor issue tps???
Old Jul 1, 2011 | 12:13 AM
mrmint69's Avatar
Re: lt1 issues
It sounds like you are trying to figure out the problem and all you know is what the HP is at right now. I would get some scanning done and see what the engine is doing. My dataMaster logs have been very good at finding them. Not sure if you took it to someone to change the computer for your mods or not.
Old Jul 1, 2011 | 11:36 PM
doferrell's Avatar
Re: lt1 issues
and on a side note. wut type of dyno did u use? once u get everything fixed and running right. there normally is a pretty good power diffence b/t dynojet and mustang dynos.
Old Jul 2, 2011 | 07:22 PM
dennis5374's Avatar
Re: lt1 issues
Sounds like spark issue. Start it up with a friend at night in the dark. Look under the hood for a light show just make sure its completely dark. Rev a little also since it sputters under accel. U can also pull plug wires one at a time and see if it changes the idle quality of the car. If no change when u pull a wire u found your problem
Old Jul 2, 2011 | 10:31 PM
PoormansZ28's Avatar
Re: lt1 issues
What does the Dyno Graph look like. Some times that can be like a map to your problems.
Old Jul 3, 2011 | 12:11 PM
Re: lt1 issues
I've seen side by side comparison of various dyno types, including comparisons of the Mustang and DynoJet, and the difference showed the Mustang reading about 5% lower. Not enough to account for the huge shortfall reported above.
Old Jul 3, 2011 | 12:26 PM
grabbem88's Avatar
Re: lt1 issues
I'm taking it that your car is auto?
How tired is your motor have you done a compression test
Was the cam degreed? installed advanced/retarded
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Z28countrymama
Jan 22, 2015 02:50 AM
ddr698
Jan 9, 2015 10:05 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
