LT1 into the 11's
Old Sep 27, 2006 | 04:10 PM
MichiganSkip's Avatar
LT1 into the 11's
How did you do it?
Start out with a bone stock LT1, add 3200 converter and 4.10's w/ A4.
what is needed to finish the job?
Old Sep 27, 2006 | 04:16 PM
2000GTP's Avatar
Re: LT1 into the 11's
Heads/cam or forced induction of some sort.
Old Sep 27, 2006 | 04:58 PM
I was looking for a little more specific info like cam specs, headwork (flow numbers, valve size etc.) TB size, LT or shorty headers, etc.
Old Sep 27, 2006 | 05:00 PM
93Phoenix's Avatar
LE2 package.
Old Sep 27, 2006 | 05:03 PM
Chopstix's Avatar
Originally Posted by s_willis
How did you do it?
I would do the following:
TQ Arm w/relocated front mounting point
LCA's
Panhard rod
Adjustible shocks
Rear sway bar/anti roll bar
Long Tubes
Cat-back
CAI
52mm TB
Tune
Slicks/skinnies
150 shot
Old Sep 27, 2006 | 05:31 PM
Severous01's Avatar
383 stroker, 3.23 gears with an a-4, cc306 cam, full exhaust, tune, 2800 stall converter, stock ported heads, 52mm tb....well, i'm high 11's but i'm still there waiting on the dana 60 rear with 3.73 or 4.1 with a t-56.
Old Sep 27, 2006 | 06:02 PM
2000GTP's Avatar
LCA's
Panhard rod
Adjustible shocks
Long Tubes
Cat-back
CAI
52mm TB
Tune
Slicks/skinnies
150 shot
I have pretty much the same setup, on paper, I am pretty sure it is capable of netting somewhere in the 11s with a good pair of drag radials.
Old Sep 27, 2006 | 06:13 PM
sam pace's Avatar
lt4 hot cam 150 shot and slicks. buddy did it all the time
Old Sep 27, 2006 | 06:24 PM
camzaro28's Avatar
LCA's
Panhard rod
Adjustible shocks
Long Tubes
Cat-back
CAI
52mm TB
Tune
Slicks/skinnies
150 shot
from that list i am missing skinnies and TB, will find out this sunday and let u guys know
Old Sep 27, 2006 | 06:51 PM
526 SS 96's Avatar
1) AI 190 cam and heads
2) 12 bolt
3) slicks & skinnies
4) BMR suspension parts; lca's, sfc's, k-member, ph rod, torque arm.
5) a decent clutch
http://videos.camaroz28.com/search/9...904a07731b.htm
The cam and head package was sweet. But you will need suporting mods. Bigger injectors, fuel pump (if you hadn't already), 58mm TB, and a full exhaust.
Old Sep 28, 2006 | 06:39 PM
Quickss96's Avatar
2) 12 bolt
5) a decent clutch
How big was your cam?? I am doing a 383 stroker with AI 190cc heads and one of their cams.
Old Sep 28, 2006 | 08:49 PM
526 SS 96's Avatar
It was real close to the GM 847. Although I have to say that that particular set up was plagued with the infamous type R lifter (long before it became a sticky ) So it was never perfect. I am sure if you talk to Phil about what you are planning to do he will steer you in the right direction.
Old Sep 28, 2006 | 08:50 PM
Shon Herron's Avatar
Why not just use what you got Stock motor will get it done, just need some weight reduction!
Old Sep 28, 2006 | 09:21 PM
camzaro28's Avatar
what is ur raceweight shon?
even though u r an M6 i dont see how i could logically reduce that much weight and run anywhere near an 11 with bolt ons. but that is a heluva 60ft
Old Sep 28, 2006 | 09:31 PM
http://www.herronperformance.com/html/shop_car.html
RW is around 3100#s with a 230ish driver.
Auto's can do it too, they just need 4.10s and a GOOD TC, and the TC needs to be in the 4kish range.
Do as much of the weight reduction you can do, get a good tire, go to a good prepped track and race on good weather days. Then work on the suspension, make the most out of what you have. Then if it isnt enough add more power, either cam/heads/juice/etc.
Talk to people that race heads up ALOT and for points/money, they will tell you to work on the 60' and then the 330', after that the rest takes care of itself. Now this is assuming you dont have a butt load of power, alot of the people we talk to are limited by rules and that is how they make the runs that are setting records too!
One of our good friends that has helped alot is NMRA Real Street driver Brad Meadows.
