lt1 intake w/felpro 1206 or =
Old 10-01-2004, 06:30 AM
Polo-94Z28's Avatar
Cool lt1 intake w/felpro 1206 or =
Just looking to see if anyone has pictures or links to some that show where a felpro 1206 (or equivalent ... 1.34 in. x 2.21 ) would land on the stock lt1 intake manifold.
Thanks much
-Zach
Polo-94Z28 is offline
Old 10-01-2004, 08:59 AM
EddieP's Avatar
Re: lt1 intake w/felpro 1206 or =
You'd probably need a LT4 intake if you are using a 1206 gasket ... I've used 1205 gaskets with the LT1 intake - don't think you can go any larger without welding.
EddieP is offline
Old 10-01-2004, 09:16 AM
Polo-94Z28's Avatar
grrrr... yeah thats what its lookin like.. thanks
Old 10-01-2004, 01:36 PM
SStrokerAce's Avatar
On top of that you might as well use the GM 12367777 gasket. 2.29 x 1.24, that's slightly smaller in area but the higher roof helps. That's not going to fit on a LT1 intake unless you weld the area above the port opening, but then you have to weld everything else up. It's just a long process of welding and then find out more problems really, lol.
Bret
SStrokerAce is offline
Old 10-01-2004, 08:18 PM
nateh's Avatar
I used the 1206 on my LT1 intake when I had the Brodix heads. It fit the heads fine, but getting the intake to match properly was difficult. I was barely able to get the mismatch to seal. I don't think it's a good idea.
nateh is offline
oldschool
02-09-2016 09:21 PM
onefastgta
03-19-2015 10:10 AM
formula218
12-02-2014 04:27 PM
thenewkid
11-27-2014 09:41 AM
07-04-2005 05:00 PM
Quick Reply: lt1 intake w/felpro 1206 or =
