LT1 intake porting & welding
Old Oct 23, 2003 | 05:05 PM
Schurters LT1's Avatar
Lightbulb LT1 intake porting & welding
What all is there to porting the intake ie:just match the intake runners to the head runners (not gasket match)
for the welding part do you just weld behind the injectors and great rid of the ski jump part and that is it? is there nothing more to this.
thx
Old Oct 23, 2003 | 05:06 PM
ianfromMA's Avatar
you talk like yoda
Old Oct 23, 2003 | 05:31 PM
S.J.S.'s Avatar
Yep....jsut match port them. As for the welding near the injectors......whatcha wanna go and do all that for. Aint worth the hastle.
Old Oct 23, 2003 | 08:56 PM
If you get rid of the ski jump the air has a smooooth shot at the intake valve, nothing in the way
JordanM made 20+rwhp with this. is there anthing more to this?
Old Oct 23, 2003 | 09:30 PM
TQdrivenws6's Avatar
Other than the fact that welding cast aluminum isnt the easiest metal to weld, no.
Old Oct 23, 2003 | 11:10 PM
turbo_Z's Avatar
Originally posted by ianfromMA
you talk like yoda
ive been told aluminum is very hard to weld on as well so that could be a slight snag if you are a novice welder. im still unclear though as to what youd do in there around the injector.
Old Oct 24, 2003 | 12:59 AM
Yes aluminum is very hard to weld , where the injectors sit behind the holes you fill that area
here are some pic of Jordons car
off the old 401, thought some of you might be interested. the blue plugs are where the fogger nozzles were
http://www.fastblackcar.com/temp/DSCF0023.JPG
http://www.fastblackcar.com/temp/DSCF0022.JPG
http://www.fastblackcar.com/temp/DSCF0021.JPG
http://www.fastblackcar.com/temp/DSCF0020.JPG
http://www.fastblackcar.com/temp/DSCF0019.JPG
http://www.fastblackcar.com/temp/DSCF0001.JPG
has any one did this with luck or have any info?
Old Oct 24, 2003 | 01:56 AM
S.J.S.'s Avatar
dont look like its worth the hassle and looks like crap on the outside. You said it gained 20hp???? Funny I've never heard of it. I sure I just haven't and I believe you. Still if it does make the power I rather find it somewhere else.
Old Oct 24, 2003 | 06:18 AM
You would not do this,20+RWHP on his 401cid, has anyone done this ?
help
Old Oct 24, 2003 | 11:05 AM
ZDriver96's Avatar
is that known as raising the runners?
Think its worth it on a 350 heads/ mild cam car?
Old Oct 24, 2003 | 11:21 AM
aggiez28 are you happy with youre intake? other then the welding could you do this youre self. did it make a diff,
thx
ZDriver96 sure the better the air flow into the heads should make a diff,
any more info?
Old Oct 24, 2003 | 11:56 AM
turbo_Z's Avatar
i wonder if having all that extra material there affects the spray pattern of the injectors.. it would seem a lot of fuel would hit the ridge and pool/drip down into the runner instead of atomizing like its supposed to. maybe im just being too overly critical.
Old Oct 24, 2003 | 12:59 PM
S.J.S.'s Avatar
Usually when they talk about raising the runners, they are talking about the roof on the runner of the heads. But as usual I could be wrong. But I just finished porting and polishing my heads and that what everyone kept refering to when I was doing them.
Old Oct 24, 2003 | 02:16 PM
ZDriver96's Avatar
yeah i talked to lloyd about it... he had some interesting info on it...
"Pretty much any LT1 that you are gonna take past 5500 RPM would benefit. I am not sure how much "better" having the runners welded like done in the pics would be on most cars. "I would expect another $100 in welding and the BIG advantage would be in raising the injector."
To bad he his server is messed up and he cant get on the forums.
Im curious on how much it'd help a LT1 with around 360-390wrhp.. aslo how it would affect the fuel spray and spraying nitrous if one decided too.
Old Oct 24, 2003 | 04:42 PM
our intake is a dry intake (air only) cab intake wet (fuel and air)
So i don,t think it would hurt the spray (nos) if anything it would be a clean shoot at the intake cyl head runner no more turbulent when hitting the ski jump
i don't think you change anything with the injector location still same spot you still ahve to bolt up youre fuel rails in the same spot
-ZDriver96 what did lloyd have to say about the intake and so on
any tip
