lt1 intake manifold part# ???
I have a couple new looking manifolds that i want to sell but i want to make sure there the lt1 and not the l99
do all 94-97 have the same part# if so whats the part#
any help would be great
Re: lt1 intake manifold part# ???
I asked Scott at lt1intake.com and here his repley
Casting # is 10108630
An LT1 will have rectangular ports.
An L99 is 12552138.
It will be tapered on one side of the port. But they can be port matched if needed to LT1 size.
I've heard of other casting #'s too, but the tapered port is the give away for the L99.
I've also seen posts by people claiming the tapered port intake was found on a LT1.
Scott
An L99 is 12552138.
Scott
There are several but I dont know what they are. the 94-95 is different from the 96-97 and I believe the B-body LT1s have a different intake as well but they all look the same from the outside.
Originally Posted by BIGCOWL-IMP
I asked Scott at lt1intake.com and here his reply
An L99 is 12552138. It will be tapered on one side of the port. I've heard of other casting #'s too, but the tapered port is the give away for the L99.
Scott
Scott
Gary
Originally Posted by A/G
The '94-95 B-body intake is identical to the corresponding F-body model years.
Brad, owning 3 B-bodies, I am going by experience when I state the casting(s) are identical. I'm also confident my 3 are representative and typical, and not special or odd in any way. I do not have an answer for what you could have personally seen that would be different. I feel we can agree that no factory manifolds had port machining done to them.
Gary
Gary
Gary
Gary
ModdedNerd
Dec 14, 2014 10:28 AM
Jul 4, 2005 05:00 PM
