LT1 intake and heads
Old Jun 24, 2006 | 12:51 AM
jmh96z28's Avatar
locking to get work on intake and heads.im trying to get to the 650-700 hp range.what can i do to the intake and heads to get thoughs #.want to put a super charger on so what specs should i get.dont no much bout this stuff so anything and everything will help.also i want them to flow better than a lt4 set up.and how much does this usually cost.labor wise i can take them apart then install them but mchining and other stuff, how much will it run
Old Jun 24, 2006 | 12:58 AM
Re: LT1 intake and heads
Any of these three packages will outflow stock LT4 heads, and the top end will put you at 500flywheelHP before the blower.
http://eportworks.com/Products.htm
Note that each package indicates the supporting modifications you will have to make, to reach that HP goal.
If you are planning a 700 flywheelHP blower motor, you will need to start from the bottom end up, with a complete, high quality forged bottom end - crank, rods and pistons, plus a 4-bolt main conversion.
oldschool
Feb 9, 2016 09:21 PM
*Emilia*
May 13, 2015 09:05 AM
MadMav
Feb 6, 2015 11:02 PM
thenewkid
Nov 27, 2014 09:41 AM
