LT1 install?
Old Apr 28, 2009 | 07:41 PM
LT1CST's Avatar
LT1 install?
Has anyone here ever or can I install an LT1 motor in an 94 Camaro with the MANIFOLDS STILL BOLTED ON? has anyone every done this? I would hate to install manifolds while in car.
Chris
Old Apr 28, 2009 | 08:00 PM
slp223's Avatar
from the bottom you can. Not sure from the top.
Old Apr 28, 2009 | 08:02 PM
bombebomb's Avatar
I think we pulled mine out of the top with the stock manifolds still on, so in theory, it can go back in with them on.
EDIT: Just checked photos, we did pull it with them on the engine.
Old Apr 28, 2009 | 08:09 PM
LT1CST's Avatar
OK cool thats what I thought. I should have some wiggle room on the sides. Im just trying to get my car back on the street. I miss my ride. Eventually Ima go with headers cam etc.. just like my old motor (in sig)
Chris
Old Apr 28, 2009 | 08:22 PM
SnakeOiler's Avatar
I pulled mine out the top with the manifolds attach. some paint came with them, though. Should have been more careful.
Old Apr 28, 2009 | 08:34 PM
bw_hunter's Avatar
Actually, installing the manifolds is pretty easy with the engine in the car. I've done it a time or two.....
Old Apr 28, 2009 | 08:51 PM
LT1CST's Avatar
Does it require me jacking up the motor unbolting the motor mount pins. I remember when installing my jet hot long tubes. I had to jack the hell out of that motor to get those headers to drop in.
Chris
Old Apr 28, 2009 | 08:58 PM
bw_hunter's Avatar
Chris
No..just feed the DS up from the bottom and bolt it on. The starter might be in the way on the PS, I don't remember. Installing long tubes was a LOT harder than bolting in the stock manifolds....
Old Apr 29, 2009 | 03:10 PM
camarobird92's Avatar
I installed my motor from the top with shorty headers still bolted in place.
Old Apr 29, 2009 | 03:18 PM
LT1CST's Avatar
OK thass cool. I think Ill have too many problems. On one of my other post I asked another question in regards to PCM. I didnt realize that 96 LT1s were OBDII. Well my camaro is 94 OBD1 wiring harness. Im picking up the motor this weekend but I wanna make sure the harness will work with the OBDII if not I got problems.
CHris
HectorM52
Jun 23, 2016 08:42 PM
Jason Short
Jan 19, 2015 06:34 PM
Fedesna
Nov 23, 2014 11:06 AM
