LT1 install?
LT1 install?
Has anyone here ever or can I install an LT1 motor in an 94 Camaro with the MANIFOLDS STILL BOLTED ON? has anyone every done this? I would hate to install manifolds while in car.
Chris
Chris
OK cool thats what I thought. I should have some wiggle room on the sides. Im just trying to get my car back on the street. I miss my ride. Eventually Ima go with headers cam etc.. just like my old motor (in sig)
Chris
Chris
Does it require me jacking up the motor unbolting the motor mount pins. I remember when installing my jet hot long tubes. I had to jack the hell out of that motor to get those headers to drop in.
Chris
Chris
No..just feed the DS up from the bottom and bolt it on. The starter might be in the way on the PS, I don't remember. Installing long tubes was a LOT harder than bolting in the stock manifolds....
OK thass cool. I think Ill have too many problems. On one of my other post I asked another question in regards to PCM. I didnt realize that 96 LT1s were OBDII. Well my camaro is 94 OBD1 wiring harness. Im picking up the motor this weekend but I wanna make sure the harness will work with the OBDII if not I got problems.
CHris
CHris
