LT1 Install
Re: LT1 Install
manual yes, automatic.. i dunno? here are some pics: http://www.lt1engine.com/messageboar...t.php?cat_id=9
Re: LT1 Install
possible, ya probably... easy, NO! I've done it once and it about near killed me! The bottom is much much easier. If you do decide to do it any way though, you better have an empty engine bay (no radiator, ect.)
Re: LT1 Install
I pulled and installed an LT1+tranny in my Formula and it was a piece of cake. Took maybe two to three hours to pull out (including removing all harnesses, hoses,etc.) and maybe an hour to put back in (with help, of course
When you put it back in make sure the car is raised pretty high. Slide a jack under the cone of the tranny and use it to roll the tranny back so it doesn't scrub the ground.
If you got any questions, PM me.
). When you put it back in make sure the car is raised pretty high. Slide a jack under the cone of the tranny and use it to roll the tranny back so it doesn't scrub the ground.
Re: LT1 Install
Originally Posted by 00JoeZ28
what exactly needs to be done in order to remove the lt1 from the bottom. Do you have any diagrams?
http://home.comcast.net/~saccani/Jef...l_Pictures.doc
http://home.comcast.net/~saccani/Jef...ne_Removal.doc
These guys have some good guides:
http://ken.lowrance.com/Projects/Hea...ineRemoval.htm
http://www.michiganspeed.com/enginepull/index.html
