LT1 Info
Old Mar 21, 2004 | 06:02 PM
techhead's Avatar
LT1 Info
I have a 94 LT1 engine that I'm wanting to add some things to. I'm wanting 450-500 hp and need some of the pro's on here to help me get started. Emissions where I live don't matter but since this motor is going in a 98 s10 blazer I want it to be drivable and get "decent millage". I guess what I'm trying to ask is what up-grades can I make without touching the bottom end and keeping the reliability.
Old Mar 21, 2004 | 06:15 PM
Brent94Z's Avatar
Super Moderator
What you are looking to do is very reasonable and pretty much describes my 1996SS. I use the car as a daily driver and it gets over 20 mpg and has 399 rwhp.
Here are the basics...
  • K&N FIPK
  • Granatelli MAF (no dyno info so don't know how much, if any, this is worth)
  • Holley 58mm tb (dyno numbers above were with a 52mm tb)
  • 1.6 roller rockers
  • $1800 labor for porting stock LT1 heads (i.e., good heads!)
  • LT4 HOT cam
  • AS&M 1 3/4 ceramic coated headers
  • Custom dual cat y-pipe
  • SLP two on the left exhaust
  • Accel 300+ ignition
  • Volt Blaster (since I'm borderline with the stock fuel system, this helps to give me a little margin)
  • Custom PCM tuning
  • Adjustable FPR (not really needed)
The car has other mods but those are the ones I can think of that could be considered to be related to hp numbers
Car now has the following instead...
  • Ceramic Coated Hooker long tubes
  • Mufflex y-pipe (no cat)
  • Mufflex 4" exhaust
There is a SOTP difference when I changed out to the above so if you do that to start with, you'll be closer (or for sure IMO) at your goal
Old Mar 21, 2004 | 06:43 PM
techhead's Avatar
Since I'm new to this stuff tell me what the following is.
Granatelli MAF
Custom PCM tuning
Cold air intake
I've seen several post talking about LT4 heads. What is the diffrence between stock LT4 heads and ported/polished LT1 heads?
Old Mar 21, 2004 | 07:45 PM
Terran2k's Avatar
http://www.thunderracing.com/index.c...ategoryid=1011
that link has pics of the Granatelli MAF and Cold Air Intakes.
custom pcm tuning, i assume he means dyno tuning.
Old Mar 21, 2004 | 10:36 PM
Red96Lt1's Avatar
Or a mail order tune (will get you close) a dyno tune is better.
Old Mar 22, 2004 | 01:59 AM
FacelessZ's Avatar
for a near stock car i wouldnt even touch the mass air flow sensor or any of its components...
cold air intake
decent sized cam depending on drivability and aspirations
matching port job on your stock heads
supporting valvetrain
mid length or long tube headers
at least a 3" catback or true duals
one big sticker on your hatch window (seen the most rear wheel gain with this mod )
Old Mar 22, 2004 | 05:38 AM
FormulaLT-1's Avatar
if you don't know what a cold air intake or tuning is I don't know if it is wise for me to suggest this, but I'd do a bigger cam.
at least a XE series, but I'm still slighty new to the internals game so my advice isn't golden.
(installing 847 tomarrow )
Old Mar 22, 2004 | 08:43 AM
techhead's Avatar
I understand the tuning aspect I'm just new to the LT1 seen. I'm convinced I will have to do something to my heads but need to know if I need LT4 heads or will porting/polishing my LT1 heads give me the same outcome. Several on this forum post quite a bit about the "Hot Cam" but I've seen several say it's not as hot as other cam options that are still very streetable. There's just so many angles here to look at and you guys have helped me get a good start. Also do I need to get a LT4 intake or have my LT1 intake polished?
Old Mar 22, 2004 | 10:18 AM
Brent94Z's Avatar
Super Moderator
I good set of ported LT1 heads will outflow stock LT4 heads. But the same guy porting LT4 heads can usually do better than if working with LT1 heads. So, LT4 heads would be better but only if you have additional port work done and that'll be a bit more expensive than just having a good port job done to a set of stock LT1 heads.
chuyz28
Jan 15, 2015 04:14 PM
Not Dave
Dec 11, 2014 06:32 PM
bernie1951
Dec 10, 2014 10:03 AM
Victory Racing
Sep 12, 2002 10:40 AM
