Lt1 idle then death
Old Nov 14, 2005 | 08:26 AM
Dfetter84's Avatar
Lt1 idle then death
My lt1 starts to cut out now ill explain exacly what it does....
Start
Engine revs to 1500 for 2 secs
then engine revs to 2000 for 2 secs
engine rev drops to 1000 for 2 secs
revs drop engine dies
my foot is no where near the accelerator pedal
wtf is wrong with the car
Old Nov 30, 2005 | 08:50 AM
Dfetter84's Avatar
Re: Lt1 idle then death
coilpacks in my case for all the SOB's that encounter this problem
Old Nov 30, 2005 | 09:36 AM
1SlowFormula's Avatar
I assume it has run since the conversion? Or is this the first time trying to start it?
Old Dec 2, 2005 | 08:09 PM
Dfetter84's Avatar
this is my second motor after the conversion
Old Dec 3, 2005 | 05:04 PM
JDBlaze85's Avatar
if you give it gas, does it continue to run or still die? scan the coolant temp sensor, tps sensor, iac counts, map sensor etc. irregular parameters.
Old Dec 7, 2005 | 03:34 PM
Dfetter84's Avatar
the problem was the coilpacks
warmeck
Feb 5, 2015 11:04 AM
Gtpguy
Jan 26, 2015 04:50 PM
edman
Jan 22, 2015 02:45 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
smacz28
Aug 6, 2002 01:51 PM
