LT1 idle and low rpm stumbling
Old May 8, 2006 | 08:50 AM
Chocolate Apocalypse's Avatar
Hey all, having an issue which just cropped up in the last week and a half or so. When up to temp sitting at a stop light the car stumbles a bit. RPM drops for a sec, once I hit the throttle its fine. Also, when cruising in OD at 1500 rpm the car does the same thing. If I push on the gas enough to shift into 3rd, RPM comes up and is fine and if in OD above 1500 no issues. Last weekend I had the car scanned and its not throwing any codes. Any idea where to look first? Thanks.
Old May 8, 2006 | 09:02 AM
Honda Hunter's Avatar
Re: LT1 idle and low rpm stumbling
clean the iac passage and t/b mabey?
Old May 9, 2006 | 09:12 AM
Right on, I'll give that a shot.
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
