lt1 hub installation
Old Mar 16, 2012 | 02:33 PM
greenformula94's Avatar
I got my hub seated against the crank gear all the way but it sticks out further than i remembered
but it seems that by referencing other pictures its on correct, heres a picture
Old Mar 16, 2012 | 02:49 PM
sandman2100's Avatar
Re: lt1 hub installation
If it is seated all the way, I'd assume it is correct. I noticed the same thing when I looked at mine a few weeks ago, but when I put the balancer and belt on it all lined up perfect.
Old Mar 16, 2012 | 03:02 PM
aight it just confused me, its been two years since this motor has been together, so no idea what i looked like, i test fit the opti and it cleans the opti so it must be correct.
Old Mar 16, 2012 | 03:37 PM
Well, if it was not on all the way, it would still clear it. You'll know more when you get the accessories on.
Old Mar 16, 2012 | 03:45 PM
I pulled the cover loose a little and its seated flat agaaints the gear so it must b fine
Old Mar 16, 2012 | 03:53 PM
Then, you're golden.
HectorM52
Jul 30, 2017 11:46 AM
1LEThumper
Jul 14, 2003 12:45 PM
Burn_Out
Aug 18, 2002 08:49 AM
