LT1 "Hot Cam"
Old Jun 18, 2003 | 01:06 PM
9TransAM4's Avatar
LT1 "Hot Cam"
hey guys, i just bought another fbody. its a 94 formula. bone stock a4. i want some instant power, and i was looking on ls1 speed.com, when i cam across the LT1 hot cam. with my new car being stock, i want to pick up just the cam. my question, is do i have to buy the rr's springs, locks and retainers? there is a huge price difference between just the cam, and the whole package. the hot cam has lift at .525/.525 and dur@.050: 218/218 LSA: 112 it says it will give me that lopey idle, and up to 30hp. what do you guys think?
Old Jun 18, 2003 | 01:11 PM
thewinner's Avatar
you need new springs too.
Old Jun 18, 2003 | 01:57 PM
Sweetred95ta's Avatar
First off, you will want the springs cuz that came pulls to about 6500 rpms and the stock springs aren't stiff enough and your valve train will float, probably not even making it to 6500. Second, the hotcam is only around a .494 lift cam without those 1.6 rr. You can use your stock locks and retainers even if you get new springs though. Also, I have the hotcam kit in my car and it isn't a "real" lopey idle. Depending on where your car is idled, you might not even be able to tell you have a cam. Finally, if you want to just put a cam in and not worry about the expensive rr's, check into the cc306 cam (comp cams). You will still need springs, but it has a big enough lift that it is over .500 even with the stock rockers. Hope this helps.
Old Jun 18, 2003 | 02:58 PM
9TransAM4's Avatar
where can i find the cc306? i was looking at ls1speed.com, but if u have a suggestion, i would like to know. so what i am looking at is the cam itself, as well as the new springs and i should be okay? also, whatever site i buy it from, do they just sell springs by themselves, because i dont want the rr's, locks/retainers, etc in the package. also, how do you like your cam? was there a nice power difference that you could tell?
thanks.
Old Jun 18, 2003 | 03:05 PM
Antz97ZNJ's Avatar
Id get some Headers before a cam....and the hot cam is known to be a little mild for some..but it is a good deal for the whole kit
Old Jun 18, 2003 | 03:37 PM
FacelessZ's Avatar
CC306 can be found practically anywhere. Try www.ftforce.com
The 306 is more of a supercharger/nitrous cam though...I'd advise an Xtreme 230/236 cam, which I was told is a much more 'streetable' cam.
Old Jun 18, 2003 | 03:56 PM
thewinner's Avatar
9TransAm4, I have a 230/236/112 for sale if you like. 200+ship. used only 200 miles never over 6100rpm.
lift is 510/520 on 1.5s 544/555 on 1.6s
Old Jun 18, 2003 | 03:59 PM
FacelessZ's Avatar
im interested
Old Jun 18, 2003 | 04:18 PM
FastZinTennessee's Avatar
My HOTcam lopes pretty good, you guys must have your idle set too high!!
John
Old Jun 18, 2003 | 04:28 PM
9TransAM4's Avatar
how is the "304" LT1 Cam, 210 / 220 with 500 / .510 114 LSA? it says it will be okay with a stock car like my formula. i am looking for somthing that will be okay with a basically stock car or a mildly modded car like my T/A.
Old Jun 18, 2003 | 11:16 PM
HOTcam is a little bigger than that "304" and it's cheaper. The HOTcam is great for a car that's otherwise stock. Just be sure and get a tune for it.
John
Old Jun 18, 2003 | 11:46 PM
SOLO Z's Avatar
question? with the hotcam kit shouldnt you be able to raise the rev limiter without worrying? for you guys that have the kit have you raised the limiter?and what did you raise it to?
Old Jun 19, 2003 | 12:38 AM
Buttercup's Avatar
#1 you need to start using the search function. Topics like this get discussed on a regular basis and might provide you with all kinds of useful information.
The cam you are talking about is usually referred to as the LT4 Hot Cam. Many people run this cam because you can buy it in kit form which also includes rockers and springs (albeit marginal ones). CMotorsports now offers cam kits as well, using their parts and CompCams camshafts.
The cams you are mentioning are all over the map. The CC306 is HUGE compared to a CC304. You need to do a little research before going any further. Decide on a cam that best suits your needs and decide on the rest of the parts needed from there.
Before diving into a cam upgrade though you need to really consider starting with the bolt-ons. You will not see near the full potential of a cam if you are still running stock cylinder heads, intake, exhaust, etc.
You should only rev as high as the engine makes power. There's no need to rev to 6500 RPM when the engine runs out of breath by 5800 (and with stock induction and manifolds that's what happens) There is also the limit that the stock bottom end can handle. Even if the heads and cam are making power at 7000 RPM, the rods do not typically live long under these conditions.
Start with the basics like a CAI, cat-back, headers, etc. and by the time you are ready for a cam you'll probably have a lot less questions
Old Jun 19, 2003 | 02:42 AM
SOLO Z's Avatar
^^^ good advice!
Old Jun 19, 2003 | 02:45 PM
FacelessZ's Avatar
Good advise...
Though I have seen a nice cam dropped into a bone stock car and producing some nice gains...but would be even better with exhaust work, head work, etc.
