lt1 hesitation problem
Old Apr 10, 2006 | 09:24 PM
shaley1975's Avatar
94 lt1 new opti,plugs & wires , egr valve and solenoid, tps sensor, maf sensor & injectors ,fuel pressure ok hesitation around 1500rpms and lack of power at low rpms runs great at higher rpms any help would be gretly appreciated almost forgot has no converter so its not plugged up. Thanks
Old Apr 12, 2006 | 05:23 AM
Guest47904's Avatar
Guest
Re: lt1 hesitation problem
Still sounds like an EGR problem. When you replaced the EGR did you clean the port in the intake and replace the gasket as well?
One other thing to try. Disconnect the hose to the EGR and plug it. Then take it for a ride.
Old Apr 12, 2006 | 08:03 PM
shaley1975's Avatar
replaced gasket did not clean the intake i'll give that a shot thanks alot, later
InfernalVortex
Jan 17, 2015 09:35 AM
bfmv13trivium
Jan 14, 2015 09:57 AM
IRABuss
Sep 7, 2011 09:08 PM
1LEThumper
Jul 14, 2003 12:45 PM
JSK333
Sep 9, 2002 10:33 PM
