lt1 help
Old Apr 20, 2017 | 03:45 PM
torquecycle's Avatar
lt1 help
I have a 95 lt1 has slightly larger cam , 36lbs injectors ,headers and holley throttle body 6 speed car putting back together my question is what mods will I need to make to cpu. and where to get it done? and if im not posting right please let me know where and how to post im a beginner, thanks in advance
Old Apr 20, 2017 | 05:56 PM
Chimera96's Avatar
Re: lt1 help
your PCM (aka cpu) needs to be re-flashed with a tune to support whatever mods you did.
A mail order tune would be OK. Whoever you use would have a form you list what mods, tire size, gears etc. along with engine mods.
you either ship them your PCM or you can buy a cable where they send you the tune and you load it from a laptop.
search LT1 PCM tuners.
there is software you can get and DIY....although a skill set that needs to be learned vs the spinal tap version of turning everything up to "11"....
Old Apr 20, 2017 | 07:36 PM
Re: lt1 help
Was this response not OK?
https://www.camaroz28.com/forums/lt1...9/bolt-741789/
That was your thread from last year that you resurrected yesterday.
